| | | Forums66 Topics128,113 Posts1,056,618 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | I bead blasted my bellhousing to bare metal, aired it off, wiped it down, dried it again, and then primed it with Rust-Ol self-etching spray primer just to prevent rusting...Now I'm concerned I should have used a high-temp primer on the bellhousing due to its engine proximity/contact.
Should it be ok with the Rust-Ol self-etch primer there? Anyone have experience with this particular self-etching primer? I'll eventually be painting the bellhousing & engine the same Chevy blue once I can get the engine repaired.
Thanks Brad Wrench Fetcher, PhD | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | "high temp" usually is hundreds of degrees, if your bellhousing gets that hot you better not be in the truck, it's burning  Bill | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | LOL, Bill - Understood... I was more wondering if what I put on it was permeable or porous? Or not the right stuff.
The bellhousing as it sits is better off than it's been in many years, I just don't want to paint it & have it come right off because I used an improper primer.
Brad
