1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
Has anyone tried the chassis paiting system that Eastwood offers. It contains thier "corrless" primer that has glass fibers or something. Its supposed to block rust and corrosion. Then after that you apply thier chassis black paint that is supposed to be chip proof. Its listed under specilty paints under chassis on the web site. Just wondering how well it works and how chip proof the chassis black really is. And did you have to sand it after primering it to apply the chassis black? Thanks! cool
"Finish the thing, do it right the first time, and drive the S.O.B.!"
1949 Chevy half ton 3100 In a kazillion pieces
2000 GMC Serria 1500 SL 4x4
mallard, I sprayed my frame with the stuff last winter. If you spray the Chassis Black within a certain amount of time ( 48 hrs I think ? ) you do not have to scuff up the Corroless. It did an acceptable job, it certainly is not chip proof. The rattle cans do not go far, I bought it in quarts and sprayed it with a gun..
As for how long it holds up, mine looks good but has only been on there a year.
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
Junior Member
Junior Member
I used there newest rust product. It has worked really well for me. Note, do all welding before you apply the paint.
ads
I got the chassis kit.I sprayed on the corolless and used the bombs for the black.My only gripe is they need to add one more can of black to the kit.
Other than that i am happy with the results.
1942 1/2ton 1951 1/2 ton 1960 biscayne sedan 1968 ihc scout 1972 #### 3/4 ton
