9 members (4tttt8, Steveoreno, 55shaker, Waveski, Joe H, RdsLessTaken, greenie-reddy, 78buckshot, 1 invisible),
62
Mod | | | Forums66 Topics128,180 Posts1,057,164 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 52 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 52 | | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Darcy,
Could be a replacement door?
Could be a late 1950 truck registered in 1951?
Could be Canadian trucks changed to vent-windows later?
What is the engine serial number?
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | is that last pic the tag of the truck? | | | | | Joined: Jul 2008 Posts: 52 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 52 | Yes it is. I`m dumb founded as to not being able to decipher this tag. I tried this site and it comes up as a 1960. Am I correct?
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I doubt if a decoder on this site would properly decode a Canadian tag.
The USA trucks had a different Vehicle Serial Number tags and they contain different codes/information compared to the third link in the first post.
| | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | Nice truck! Canadian, eh... good luck on the cipher'n  | | | | | Joined: Jul 2008 Posts: 52 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 52 | Thanks guys. Just was worried the tag was messed with. Darcy | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Here is the pertinent information for DADS50 link (nice find - this had been posted by a Hemming site for many years and then it disappeared):
1950: 0 then: 11/91 then 32 etc. 1 ½ Ton 137” w.b. 29.4 H.P.> 11/91 then 42 etc. 1 ½ Ton 161” w.b. 13/93 then 12 etc. ½ Ton 116” w.b. 13/93 then 14 Pick-up Delivery 116” w.b.
As DADS50 posted: 01314 preface = 0 13 14 = 1950 Pickup Delivery 116" w.b.
| | | | | Joined: Jul 2008 Posts: 52 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 52 | Thank you sooo much!!! Wish it had a delivery logo on the side..!!!
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy darcy32171, your serial number is that of a Canadian 1950 Chevrolet pickup, hope that helps. Happy Canada Day! | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Jul 2008 Posts: 52 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 52 | DADS50, I`m sure it has. There is a couple scratches that shows an orangy color underneath. | | | | | Joined: Jul 2008 Posts: 52 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 52 | This truck was Willed to him by his late brother. He was told his nephew had been horsing around at the farm with it and it quit. He figured it was the timing chain. Wasn`t till I got home to see videos that they don`t run a timing chain. I can roll the fan back and forth and the crank moves, but it locks up. Until I get a gasket set for this 216, I`ll wait. I want to pull the side covers and see if it isn`t a bent push rod or something.
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | So that's the way GM tagged Canadian trucks? It resembles later US trucks and cars.. Wish I had that style on my '50 instead of the stamped/printed style it was issued with. The other style gives more info.
Drew
| | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | So that's the way GM tagged Canadian trucks? It resembles later US trucks and cars.. Wish I had that style on my '50 instead of the stamped/printed style it was issued with. The other style gives more info. Thats what I was thinking! Thats nice to have all that info there! | | | | | Joined: Jul 2008 Posts: 52 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 52 | I think they had the 216 in it. Which ones had two bolts holding valve cover on and the long single cover over the push rods? I thought all flat six`s had the dual covers. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | You double posted this question. What dual covers are you referring to? https://www.stovebolt.com/ubbthread...in=153343&Number=1039001#Post1039001All 216/235/261 engines had one side cover. These engines are in-line sixes (not flat six?). Most likely you have a 216. In Canada, some 216s and some 235s has long side covers or short side covers. You need to ID the year and size of your engine. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Please post any other engine questions in your thread in Engine Shop.
Thanks. | | |
