2 members (pauld, Goach2),
68
Mod | | | Forums66 Topics128,185 Posts1,057,286 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 122 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 122 | Problem is bolt pattern on bell hsg does not match tranny. The tranny pilot hole is the same dia. so the tranny will fit up but not bolt up. Can I drill the hsg to fit the tranny bolt pattern? Don't know of any other way to make the matchup. Thoughts or concerns will be appreciated | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | It looks to me like you need a 1938-39 pass bellhousing for your 1937 pass with a later 235.
See the USA in your vintage Chevrolet! My Blog | | |
