| | | Forums66 Topics128,031 Posts1,055,435 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 205 | Hey guys and Gals, I've come across a 1959 Chevy Apache with the 5 window configuration. Can anyone share some info on this?
Scott
Chevytruckdaddy
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 'restored' truck or unmolested original? I believe those cabs were only used on the largest series trucks, although I've heard of folks swapping them onto light trucks .... no idea why GM did that or how many years it was used .... the only ones I've seen were GMCs, like this'un - corner glass unobtanium Bill | | | | | Joined: Jan 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 205 | Awesome Bill, so I'm guessing they're not so rare and not worth much? I know a just selling the cab. I'm looking for a replacement to my 58 small back window to a big back window, but came upon this.
Your thoughts again!!!😏
Chevytruckdaddy
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | well they're not common, I've seen a couple and heard of a couple others, and if they were only on the GMC big trucks, there won't be a lot left, but I'd say worth about the same as any other TF cab, which depends on condition .... I've always thought they were kewl, but don't know I'd actually use one, and you'd definitely need to make sure you got good corner glass with it .... also, make sure it is a Chevy dash, it's no fun changing out dashes!
Bill | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Why would anyone want to replace a beautiful GMC dash with a Chevy one? | | |
