6 members (32Fordpuchoptop, Youngin' Tut 59, treegrower, Gray_Ghost, Wickedbass, WICruiser), 66 guests, and 3 robots.
Topics128,076
Posts1,055,922
Members48,430
#1038674 06/29/2014 7:57 PM
Working on '49 3600 and we are to the point of pulling the cab. What do you do with the gear shift and parking brake?
Dave
newbie
DaveBPT #1038698 06/29/2014 9:20 PM
Dave,
3-speed or 4-speed?
Is parking brake on/near the top of the 4-speed transmission, or is is a foot-pedal actuated parking brake?
DaveBPT #1038711 06/29/2014 10:34 PM
Dave - you can pull the gear shift out by pressing down on that retaining ring around the top of the stick and then turning it counter-clockwise. Its a bit of a pain, but it will turn. I actually took an 18 inch two-by-four and drilled a little notch in it so that I could press down with some pressure and still turn it.
