| | | Forums66 Topics128,070 Posts1,055,900 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2014 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2014 Posts: 41 | Working on '49 3600 and we are to the point of pulling the cab. What do you do with the gear shift and parking brake?
Dave
newbie | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Dave,
3-speed or 4-speed?
Is parking brake on/near the top of the 4-speed transmission, or is is a foot-pedal actuated parking brake?
| | | | | Joined: Sep 2011 Posts: 255 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 255 | Dave - you can pull the gear shift out by pressing down on that retaining ring around the top of the stick and then turning it counter-clockwise. Its a bit of a pain, but it will turn. I actually took an 18 inch two-by-four and drilled a little notch in it so that I could press down with some pressure and still turn it. | | |
