2 members (TUTS 59, Leo),
62
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2013 Posts: 52 'Bolter | | 'Bolter Joined: Jun 2013 Posts: 52 | My son and I are restoring a 53 chevy pickup with the a complete frame off project. We have upgraded the brake master to a dual reservoir. Is there a new schematic that we could use to perhaps rerun the lines to take advantage of the new master? currently I have one line going to left front and second line going to the remaing three wheels.
My thinking would be to have 1 reservoir servicing the front 2 wheels and 1 reservoir for the back 2 wheels. Does that make sense? Is it needed? if so, any recommendations on line sizes?
Thank you for the help
53 3100 purchased brand new by my wife's grandfather... full frame up restore in progress.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | My '56 was plumbed 3 and one also. When I installed the dual master cylinder I plumbed it 2 and 2. Though the article is for a '56 there should be info you can use for your '53. | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | You'll want the front wheels on one line and the rear wheels on another. Are you still using the drum brakes front and back?? With 4 wheel drums you'll want a master cylinder with equal reservoirs/ pistons.
John | | |
