| | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2003 Posts: 10 Member | | Member Joined: Jan 2003 Posts: 10 | I'm curious if anyone has any experience with Hammerite paints by the Kilz company. I've used it for some recent large projects around the house and some small projects on a truck I ended up selling soon after. But I'm wondering if anyone knows the dry/cure time, durability and comparison to such great products as ZeroRust and POR-15. Any replys, comments, or suggestions are greatly appreciated.
-GLC- | | | | | Joined: Jan 2003 Posts: 26 Member | | Member Joined: Jan 2003 Posts: 26 | I'd also be curious about Hammerite for at least the frame. This Summer I'm planning the restoration process but section by section. I don't have the room to do a full dismantling. I would take the frame down and have it chemically stripped but I'll have to work with sand blasting and wire brush. That won't cut it for the real nooks and cranneys where rust never sleeps. The maintainance guys down at the harbor sware by Hammerite to 'incapsulate' the rust. They say the stuff is bullet proof on rustable metal with a constant bath of salt spray. | | | | | Joined: Jan 2003 Posts: 10 Member | | Member Joined: Jan 2003 Posts: 10 | Originally posted by Rattletrap52': I'd also be curious about Hammerite for at least the frame. This Summer I'm planning the restoration process but section by section. I don't have the room to do a full dismantling. I would take the frame down and have it chemically stripped but I'll have to work with sand blasting and wire brush. That won't cut it for the real nooks and cranneys where rust never sleeps. The maintainance guys down at the harbor sware by Hammerite to 'incapsulate' the rust. They say the stuff is bullet proof on rustable metal with a constant bath of salt spray. Do you have any place in mind for the sand blasting? My truck is in pretty good condition considering it was hauled out of Big Bear, but I'm planning a total restore some time in the near future. The Hammerite will be used on undercarriage and engine compartment components including the 1990 Camero rearend I'm currently building to replace the original (with 3.42 posi). I'm curious as to what the harbor maintainance guys say about the durability of Hammerite is (against chips and dings, etc.) and how long the cure time is. Maybe you could find out for me?  Thanks... -GLC- | | | | | Joined: Jul 2002 Posts: 68 Member | | Member Joined: Jul 2002 Posts: 68 | When I rebuilt my trans, I painted it with light gray Hammerite. I did this about a year ago and so far it is holding up great.
'54 3100-235-T5 trans-12 bolt 3:31 '68 Impala 307/350 '78 Sportster/Original owner
| | | | | Joined: May 2002 Posts: 17 Member | | Member Joined: May 2002 Posts: 17 | I used Hammerite on my heater box and it seemed to work fairly good and is holding up really good. It took me a little while to find it where I am, because I started my search at Auto Body Supply places but the only place I finally found it was at the Home Depot Good Luck | | | | | Joined: Jan 2003 Posts: 10 Member | | Member Joined: Jan 2003 Posts: 10 | I can get Hammerite at Vista Paint supply near my home for about +/- $3 a can...from what I've learned, that is a pretty good price.  I'm really curious about the dry/cure times and durability against chips and scratches and how it compares to ZeroRust or POR-15 (I've read that POR-15 is nearly bullet proof!)...Thanks for your replies!! -Geff- | | |
