7 members (msmall, Otto Skorzeny, Phak1, 55shaker, TUTS 59, Wayne67vert, 1 invisible),
106
Mod | | | Forums66 Topics128,095 Posts1,056,069 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | My original 3-speed transmission that I had professionally rebuilt works well. However, it is leaking oil from the shift shaft seals. I am guessing the rebuilder did not replace the seals. Anyone know of a source for the seals and the model of the transmission. I thought it is a (LD) Muncie, but beyond that I don't know the official designation to look for parts. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Have you tried these guys? http://pistolestransmission.com/ They have been working on manual transmissions for a long time and they know where to find stuff. | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | LOL, that is who rebuilt the transmission. They are notorious for not changing seals or using gaskets. This is the second transmission from them that leaks somewhere. But, the good news is that the transmission works well.
I don't think pistoles sells parts, but I will give them a call. Maybe they will give me a source. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Depending on what year transmission you're dealing with, some have seals that are essentially the same as the output shaft seal or axle seal, only smaller, and some use O rings. I believe the change on the 3 speeds was either '56 or '57. In either case, you should be able to take one of the old seals to a local parts store and have it matched up. I don't thin I still have the numbers for them, but that's what I did when I went through the SM319 in mine.
Bill Burmeister | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Finally found what I needed at Chev's of the 40's. Too hard to find online, but easy with the catalog (was at office). | | |
