7 members (HandyAndy, Tiny, TUTS 59, Southerntruck, 66flea, klhansen, 1 invisible),
88
Mod | | | Forums66 Topics128,092 Posts1,056,043 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | I'm confused about mounting the T5 to the 216 housing. I have an adapter plate. Everything I read says to drill out the holes on the T5 to 1/2". But the upper holes in the 216 seem to be 7/16 threaded.
So do the upper 2 bolts thread into the bellhousing (and is so, can anyone confirm if the threading is 7/16 or 1/2 or...?)? Do the lower 2 connect with a nut inside the bellhousing? Are these 1/2" | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | What year is the 216. All the ones ive worked on have been 1/2 in. Yes you do need to use bolts & nuts on the lower ones. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | I unfortunately have no idea what year it is.
Maybe the holes are dirty and the 7/16 is just threading the dirt. | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I believe 7/16" holes are 14 threads per inch, 1/2" are 13 threads per inch.....
John | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Let's see if we can figure this out. You have an adapter plate that will bolt to your bell housing like the tranmission normally would. The upper bolts due thread into the bell housing and I believe they are 1/2 in. The lowers were a bolt with a nut. Drilling the t5 to 1/2 inch is done becuase the holes in the case are smaller (metric). This drilling should not be done on the bell housing, only on the transmission case.
It should all bolt together with the original bolts, with the exception that they will need to be a little longer because of the thickness of the adapter plate. Hope this helps.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | Thanks all. Cleaned the housing and it does thread 1/2. Tranny case is drilled out and T5 is ready to install. Now which way does this TOB go again?  | | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | Can anyone tell me how to get a socket on the top right bolt? The 1/2" head is a 3/4" socket and even the smallest I have won't fit. | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Try using an allen head bolt, thats what the factory used.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Maybe a 3/4 wrench?? John | | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | Try using an allen head bolt, thats what the factory used. Ah, that's right. | | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | Maybe a 3/4 wrench?? John No way a wrench would fit. | | |
