| | | Forums66 Topics128,093 Posts1,056,477 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2003 Posts: 93 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 93 | ...just an update on the oakie oil seal replacement in my '47 torque tube. It's a ton of work just to replace an oil seal. Chris Sweets tech tips was a huge help ! Anyone needing to do this will need to remove the drive shaft and make a tool to drive out the Oakie without damaging it. I used a 6 ft. length of thick wall pipe with a mandrel machined to fit inside the bushing. I do not believe it would be possible to pull the bushing out from the front 'cause it's extremely tight. Anyways, the seal part # is SKF 10515. I machined out the bushing to accept two seals and put in a double seal. | | |
