8 members (Oldcaliforniakid, Otto Skorzeny, jmoore, frogfarmer, Hotrod Lincoln, 49nut, Stovebolt48, mason86),
114
0
Mod | | | Forums66 Topics128,050 Posts1,055,671 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 81 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 81 | I have the cluster apart for rebuilding and was wondering what cleaner is recommended for the fine odometer, speedometer and gauge parts?
Thanks!
gobolt
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | be real careful on the odo wheels, the painted numbers flake off easily - on metal parts I've used Brake Kleen
Bill | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The color will come off any painted surface regardless what you use. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Scribe a mark on the side of each wheel next to 0 before cleaning for a reference mark to install the new numbers. | | | | | Joined: Dec 2009 Posts: 81 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 81 | Thank you all - another question:
All gauges and the speedo are original and were working when the truck last ran 4 years ago. However, I'd hate to have to pull back apart at a later date. Upside to replacing gauges would be to minimize this risk, downside is cost and the fact that the repos aren't quite the same. I am leaning towards keeping the old gauges and have scanned the site for ways to test them...found help on all but oil pressure gauge - any way to test it?
gobolt
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if they were working before you removed them, then don't damage anything and they'll keep working, installing new gauges is more likely to result in problems, you don't know the defect rate on those and it's not uncommon to find new parts defective .... the oil pressure gauge is the easiest, just hook it up and start the engine - being a mechanical gauge, it's the least likely to go bad .... other than leaking because you messed up the fitting
Bill | | | | | Joined: Dec 2009 Posts: 81 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 81 | Bill -
Thanks for all the help - the tech tip pictures are invaluable. Unfortunately, the copper spindle that the needle attaches to failed when I (gently, but not gently enough apparently)attempted to remove the needle to refinish the gauge face (broke at the point it passes thru the bar). It appears this is the end of this speedos life.
gobolt
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | sadly, not uncommon - if you can find another speedo for parts the shaft and part it attaches to inside the bell can be replaced
Bill | | |
