3 members (Stewart2, Hanks custodian, 1 invisible), 64 guests, and 10 robots.
Topics128,014
Posts1,055,324
Members48,419
#1037836 06/25/2014 5:43 PM
will a 235 from a 57 bolt into my 1950 3600 with 4 speed. Is this a better choice than my 216?
evac34 #1037846 06/25/2014 6:22 PM
It's almost a bolt-in, just some possible issues with front motor mount adapting and an the position and length of the water pump. Both concerns are solved pretty easily. A post-1954 235 has a different, and "better" in the opinion of some people oiling system for the connecting rods, also slightly more horsepower than the 216.
evac34 #1037847 06/25/2014 6:25 PM
It's a better choice in that it's a later engine with a little more power and will be easier to obtain parts for through a local supplier, like NAPA. You'll have to drill the front engine plate or transfer the 216 one for the front crossmember and you'll have to use the 216 bellhousing for an easier fit. It's a good swap I think if you want to do it.
Drew
evac34 #1037906 06/26/2014 1:45 AM
I believe that you can use the front plate from your 216 on the front of the 235. Also with the water pump relocation plate you can use water pump from the 216 in it's original position.
1951 1 Ton Completed
evac34 #1037938 06/26/2014 3:50 AM
And BE SURE to make it where all the timing cover bolts screw in from the front.
Evan
