| | | Forums66 Topics128,127 Posts1,056,675 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 25 New Guy | | New Guy Joined: Dec 2012 Posts: 25 | Is the wear/pitting on the axles normal or a cause for concern? I had planned to replace the bearings and seals. Now wondering if axles need work also. Opinions and advice would be appreciated. First 2 pictures are the right axle and the last 2 the left. https://www.dropbox.com/sc/xqjq56rxbth9zyr/AAAG4PIRIvptQ9BMecdphDNxa | | | | | Joined: Dec 2011 Posts: 112 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 112 | coker91 I would not trust axles in that condition in my truck. They should be replaced to be reliable. My opinion. Good luck Delky dave in WYO
1957, 3100, v8 2016 gmc 4wd
| | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | Did they come out that clean? Looks like heat with the bluish hue. Any grease around them? Either way replace them
| | | | | Joined: Dec 2012 Posts: 25 New Guy | | New Guy Joined: Dec 2012 Posts: 25 | That's what I figured. I appreciate the advice. Yes there was grease on them when I took them out. I clean them with a little mineral spirits for the sake of the picture. | | |
