1 members (Oswald),
243
Mod | | | Forums66 Topics128,162 Posts1,056,942 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | I'm gathering everything I need for a T5 swap in my '53 1/2 ton. I plan to use a '59 3.90 center section. I've read in the tech tips that a drive shaft from a 90s Astro van will work for this swap.
(1) Is this with the rear end in it's original location?
I haven't decided if I'm going to leave mine where its at or move it back to center the wheels in the fenders. If I decide to relocate the rear end,
(2) what drive shaft comes closest to fitting?
I'll be doing this in a friends garage and this is my daily driver so the smoother this goes the better. I need to have everything ready before I start because I don't have the luxury of spending a couple days scouting for a drive dhaft with my truck on jack stands. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I wouldn't worry with trying to find a drive shaft that will fit perfectly because it will be tough to find one the correct length. I would find one that is long enough and have it cut to the exact length and have them balance it while they are at it. There should be a drive shaft or machine shop close to you that can do that for you.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | (1) I would like to know if others have found the Astro van drive shaft to be a perfect fit. (2) In the event that I center the wheels in the fenders I do not expect to find a drive shaft of a perfect fit, but I would like to know what other people are using. Then I can have that shaft on hand to have it shortened. | | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | I would agree with the advise that 6 cylinderovertexas is giving you. http://www.dennysdriveshaft.com/app/webroot/img/File/how_to_measure_diagrams/b.htmlThis is exactly what I did in my 51 Chevy shortbox build. In my case once the rear differential and transmission were in place I measured the exact distance using the above link as a guide. After very careful measurements, the 93 Astro shaft was taken to the machine shop cut,balanced and welded back together. Once I got it back everything fit very well.I've been running it for about 2 years now with 0 problems works very well. Hope this will help you out. | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | I used a 77 olds cutlass driveshaft for my 46 1/2 ton when switched to a t-5 i did have to get it shortened 6 inches tho, Im pretty sure any midsize gm driveshaft will work, just a matter of cutting to fit | | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | Here's an update on my use of an Astro van drive shaft when replacing the three speed with a T5 5 speed and the torque tube center cection with a '55-'62 center cection.
It works.
I moved my rear end back 1.5"
I used a 'swap adapter' from Hamilton intakes which moved the 5 speed back about 3/4"
The Astro van yoke was actually 1.5"-2" longer than the S10 yoke making the Astro shaft too long. I swaped the Astro yoke for the S10 yoke and the thing fit perfectly.
This worked for me. I make no guarantees. I hope this helps someone else. | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | THANK YOU for the update! All too often folks forget to tell others how things worked out.
This is timely for me since I will be bolting up my T5 this weekend. I might need to go grab an S10 yoke or at least compare the S10 yoke length to my Camaro yoke length. | | |
