0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 13 New Guy | | New Guy Joined: Feb 2014 Posts: 13 | Finally took delivery of my 37 yesterday. After a short drive, i noticed "water" dripping out of the lower left side of the radiator. It looks like a small outlet tube, but no hose was attached. Am I missing something here? Can't seem to track the info down. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | in the bottom tank of the rad? that'd be the drain petcock - if a 'small tube' that runs down the side of the rad frame from the top, that'd probably be the overflow tube, which can 'dribble' after running if the rad is overfilled, need to keep the water level at least an inch down
Bill | | | | | Joined: Feb 2014 Posts: 13 New Guy | | New Guy Joined: Feb 2014 Posts: 13 | Thanks Bill, it's the small overflow tube. I will check the levels. | | | | | Joined: Sep 2010 Posts: 1,707 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,707 | Finally took delivery of my 37 yesterday. After a short drive, i noticed "water" dripping out of the lower left side of the radiator. It looks like a small outlet tube, but no hose was attached. Am I missing something here? Can't seem to track the info down. I hooked a clear tube to the overflow. I put the loose end in a mason jar and use it for an overflow bottle. I did have to make a small bracket to hold the mason jar. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I actually run an over flow tank on my 37 and I have it mounted inside the grill chin under the wind dam that goes from the front of the chin up to the bottom radiator. It is a nice size, but small enough to hide in that spot. I have found if I keep a piece of hose running from the radiator overflow tube into the bottom of the overflow tank, it will fill when hot and draw the water back into the radiator when it cools down. I haven't added any water or coolant to the radiator in years. It works like a closed system because I closed it with the overflow tank. Pressure on the cap doesn't make any difference as long as it is a "closed" system.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | I added an overflow tank to my 49 216 and haven't had to add any anti freeze since. Likes been posted, when the engine heats up to operating temp it'll fill the overflow tank about 1/3rd up and when I shut it down and it cools off it'll suck the fluid back into the radiator. It actually fills the rad up to the tip top when cold. I've since sealed the overflow tank off better. Theres some nice aftermarket overflow tanks available by just about all the classic part retailers. Dave | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | As has been mentioned, the best method is to use an overflow tank. However, the system can work just ifne without one, you simply need to let the radiator find its level, and not continue filling it otherwise it will continue puking. | | |
