1 members (1955 1 Series),
64
Mod | | | Forums66 Topics128,169 Posts1,057,102 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 24 New Guy | | New Guy Joined: Mar 2014 Posts: 24 | I've rebuilt a couple carbs before... but never had one where this little "T" spring retainer wouldn't budge until now... http://i1200.photobucket.com/albums.../IMG_20140619_215740_059_zpsl63nocje.jpgI think i'm just gonna go ahead and dunk it in the carb dip tomorrow and see if it loosens up any. Any other suggestions to help get it out?
| | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | what I did with mine was let it soak real good and then use the needle nose pliers and took it out. the kit should come with a new one. heres a video on the rebuild mikes carb rebuild rochester b
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | This reminds me of my dad. He was one of those guys that could do anything. So when I said, Dad, I cant get that out of there, he would say, PULL IT OUTTA THERE!! Real loud. Works EVERY time.  | | | | | Joined: Nov 2002 Posts: 2,771 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,771 | As suggested above, use a pair of needle-nose pliers.
Grasp the retainer with the pliers, and apply a slight twist in both directions. Then just pull it out.
The kit will have a new one. Seat the new one with a drift punch.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
