My hood for my 45 GMC 1/2 ton has 4 sections. Two upper pieces which consist of a left and right, and two lower pieces, again, a left and and right. One of the two top pieces, has a slight bow to it where it meets up with the cowl. It does not lay flat like the other side. It's not bent, or dented, just has a larger curve where it rests on the cowl, which now gives it a bad fit. SInce the hood is all sheetmetal, with no rolled over edge, or bead,, and no back panel for support, how do I straighten out the bow, to get a proper fit. I can take the hood, and press it down, and it just springs back since there is no support. Any metalworking suggestions? I was thinking of adding another piece, about 1/2" wide, to the bottom side, and seam weld it. THis would add some strength. PLease help with suggestions.
THanks
