2 members (Joe H, PAUL Berardi),
140
Mod | | | Forums66 Topics128,111 Posts1,056,246 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2013 Posts: 17 New Guy | | New Guy Joined: Sep 2013 Posts: 17 | Hey all, Recently picked up an all original 1952 3100 with the 6 volt electrical still in tact and working great...except for one thing. The headlights only work on low beams. When I hit the dimmer switch, the light comes on the dash indicating that high beams are on but the headlights go dark.
On suggestion from a friend I purchased a new dimmer switch and installed it last night. Still the same thing...low beams work, high beams do not.
Any other suggestions? Not sure if the headlights are original or if that could even be the problem area.
Thanks! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | did you check the function of the old switch with a meter? have you done continuity checks on the wiring? have you tried changing one or both bulbs? you're the only one that can put hands on the problem, and an ohmmeter should solve it
Bill | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Are there any connectors between the fuse box or whatever system it uses that could be dirty? I had a similar issue on my '62 Bel Air, and the fix was to clean the connectors on the back of the fuse box. This was after I changed the headlights, dimmer switch, fixed the grounds, etc. Check all connectors first, and get friendly with the multimeter and test light. | | |
