2 members (NJC, 1 invisible),
109
Mod | | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2014 Posts: 4 New Guy | | New Guy Joined: Jun 2014 Posts: 4 | 55 first series shock problem. I am trying to install my new rear shock. Upon removal of my old one, I broke off the rear shock's lower bolt or stud. I would like to know how to remove the remnants of the broken bolt from the ear of the leaf spring where it is attached. Is it splined and needs to be driven out through the back, or is it swedged and needs a good beating or drilling? Thanks - Scott | | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | I have a 51 3100 and i actually found replacements on the internet pretty cheap (i think $20?). I am not sure where i saw them. Might be easier to just replace it? I removed mine pretty easily by loosening up the ubolt and it slide right. I am not sure if yours is the same way or not.
Chris | | | | | Joined: Jun 2014 Posts: 4 New Guy | | New Guy Joined: Jun 2014 Posts: 4 | Thanks for the reply. I found something close in the catalogues, but on mine the bottom plate of the leaf spring bracket has an ear on it for the stud. The catalogue ones were just a "L" shaped piece that appears to bolt onto 2 of the 4 leaf spring bolts. I mostly want to know how the stud on the lower shock mount can be removed. Thanks again-Scott | | |
