| | | Forums66 Topics128,054 Posts1,055,780 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 43 | I have a 1964 C10, fleetside, LB. I am at a cross roads between either making the truck original or modified. It did not come with an engine or trans., but I think it had a 283 and the trans. was a manual. My questions are:1. How well does an original truck stop on all drum brakes? 2. Did the 283 have a specific manual trans., or is there a way I can tell by the shift linkage (it was on the column.)? 3. Is there any way to tell for sure what engine this may have had? 4. How hard is it to maneuver w/o power steering? (Contacting the person who took out the eng. & trans. is not possible.) Thanks! Janine | | | | | Joined: Feb 2014 Posts: 215 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 215 | Does it still have the build tag on the driver' side kick panel? It will help you identify what was there.
Disc brakes are far better. Mine has a '73 front end in it. Fairly easy swap. Also have a '78 tilt power steering, and a '75 3/4 ton rear end.
The column shift would indicate a 3 speed manual, or automatic.
Which ever way you go, have fun!
| | | | | Joined: Jul 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 43 | The build tag has been painted over, but I can make out some of the numbers. 5000 : which I think is the load, 8 TD 503 (503 I know is the color) But the 8 and TD ??? and then 127 is the wheel base. (Note: Its was a manual since there's a clutch pedal.) | | | | | Joined: Feb 2014 Posts: 215 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 215 | Does it still have the radiator? The 230 L6 had a radiator that was 18" wide x 1.26 deep. The 292 L6 and 283 V8 had one that was 25.22 wide x 1.98 thick. (Although they may have been replaced by now.)
I can't find the build codes now.
| | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | I have no power steering and low pro tires on my 65 long bed. It turns fine. I don't have drum brakes all around though. Disc up front. Original is a nice option. Lots of guys rat rod these trucks. It's all up to you my man. I ordered everything from earlyclassicenterprises.com. Whatever you decide, there's tons of experience on this site. Great people here.
| | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | My questions are: 1. How well does an original truck stop on all drum brakes? 4. How hard is it to maneuver w/o power steering? Thanks! Janine My '65 has 4 wheel drum non power brakes and does not have power steering. 1.0 It stops fine IMO. I can lock up the tires if I mash the brakes hard enough. 4.0 As for steering, as long as you use a large diameter steering wheel, 15" or larger, you will be good to go. Keep in mind that people drove cars from the early 1900's through the early 1970's before front wheel disc brakes or power steering became mainstream and standard equipment. But also keep in mind it will not stop nor steer like a modern day vehicle. Happy Trails, John  | | | | | Joined: Jul 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 43 | There is no radiator, or inner fenders, but the guy who sold it to the guy I bought it from had taken a 283 to an eng. shop and never had them work on it, so I think it was from this truck.I looked at the motor mounts too, no rear ones, but looks like there may have been 1 on either side of the cross member. (The front end has already been epoxied over.) I also took another closer look and I am sure that it had a 3 spd trans. by looking closely at the linkage that is still there and comparing it with pics & diagrams. So, with the info I have gotten so far from ya'll I think I might just stick with original. They are becoming rarer and I am also currently doing a frame off restro on my '65 SB, Stepside, with a rebuilt 350 and 700R4. Thanks, all! Janine | | | | | Joined: Aug 2006 Posts: 237 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 237 | I have a 64 with as close to factory setup as possible. It has the factory steering wheel as well as drum brakes. I do not drive mine every day nor do I drive it fast when I do. If I were on the interstates and driving it to work etc... I do think I would like power steering and power brakes.. Of course that is my opinion... I like things more original. I have a cousin that hot-rods everything he has.. I think that messes it up, but that is his trucks and his money. in my opinion, I would never cut a long bed down into a short bed..that is just me..
Jesus is Lord! Only through the blood of Jesus are you washed clean of your sins. Come see us... Dad's Chevy Our VideoGod bless you! Michael..
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I've put disc brakes and power steering on several of these trucks, its easy and reasonable in cost if you do your homework. Most folks cannot even tell the modifications aren't original, and it makes driving in today's traffic much safer and much much more enjoyable. | | | | | Joined: Jul 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 43 | I decided to rebuild the rear brakes as original and thought that would give me time to make up my mind on how I want to build the rest of the truck, (I am leaning toward original now that I've read your posts) but as things go...while spinning the axle hub I noticed that differential fluid was pouring out from behind the yoke. I sure hope it's just a seal! The fun just never stops! ;-) Janine | | |
