7 members (tclederman, Woodcmiami, Hotrod Lincoln, Otto Skorzeny, 2-Ton, bobfake, 1 invisible),
41
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,091 Posts1,056,034 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 27 New Guy | | New Guy Joined: Apr 2012 Posts: 27 | I've got a 235 in my 49. Which Iline 6 will give me the most hp, while still being a direct bolt in?
It's not the weight of the load, that breaks your back. It's how you carry it.
| | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | The 261 engine, which was used in midsize and larger Chevy trucks from 54-61 will be the closest thing to a direct bolt-in you will find. The GMC 270 and 302 engines will be close, but they will require front motor mount modifications to accomodate the 2" of extra length and a relocation of the radiator forward a little if possible. The GMC engine is a direct bolt-up to the Chevy bellhousing, however. Jerry
| | | | | Joined: Apr 2012 Posts: 27 New Guy | | New Guy Joined: Apr 2012 Posts: 27 | What about 292? I was looking at the below link. Certainly like the idea of hyd. lifters. http://rebuilt.net/Chevrolet_6_Cylinder_Engines.htm
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The 292 would not be a direct bolt up. It would require a different bellhousing and motor mount would have to be fabricated.
Bill Burmeister | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | The GMC 270 and 302 are great engines. In the old days, all the round dirt track racers loved them.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | |
