1 members (walterhvogel),
87
Mod | | | Forums66 Topics128,035 Posts1,055,559 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2001 Posts: 15 Member | | Member Joined: Jul 2001 Posts: 15 | hello,im looking for a link to a webpage whom sells sandblasters,and more leaning towards a cheap one  thanks
Its not a truck unless you can throw a dead cow in the back
| | | | | Joined: May 2001 Posts: 71 Shop Shark | | Shop Shark Joined: May 2001 Posts: 71 |
'53 Chevy truck 1/2 ton
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | I had one of those cheap ones from H F I had realy good luck with it . Be sure to pick up a few extra tips | | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | Well, I have one of those pressure blasters from HF, and I have NOT had good luck with it. Clogs up really easy, uses lots of sand when it does work. Gave up on it and bought a siphon blaster from Sears. Much better. No clogging, and sand lasts much longer. Just not as effective as a pressure blaster (takes a little longer to do the same job), but with the HF blaster always clogging and having to take time to declog, I think it is faster to use the siphon blaster. I also bought one of those cabinet blasters from HF when they were on sale, and have had good luck with it. The gun has already been worn out, tho, so I am using the gun that came with the Sears blaster in the cabinet (also a siphon set-up), and works great! The only problem I had on the HF cabinet blaster is the gun's tips wore out and it seems HF discontinued selling replacement tips. Which makes the gun worthless. | | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | Brian, I found the same thing to be true. I was thrilled ot get my pressure blaster home from Harbor Frieght, only to find that it didn't work as good as my old siphon blaster. Even my little hand held "Speed blaster" works better.
1948 Chevy Pickup Chopped and sectioned owned since 1974 when I was 15.
| | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | By the way, I found that the pressure blaster used WAY more sand to get the job done.
| | | | | Joined: May 2001 Posts: 71 Shop Shark | | Shop Shark Joined: May 2001 Posts: 71 | Another tip, once you get the blaster, try several different size tips to get the right combination. Once you have plenty of air and get the right size, it works way better than other sizes from my experience.
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Another place to try is Nothern Tool .
Fred 52 3600 69 C-10
| | | | | Joined: Jul 2001 Posts: 15 Member | | Member Joined: Jul 2001 Posts: 15 | what is the best tip to tear into the cab rust and old paint? :confused:
| | | | | Joined: May 2001 Posts: 36 Member | | Member Joined: May 2001 Posts: 36 | To make the Harbor Freight pressure blaster work I did this. 1) Pre-screen all your sand thru an old window screen & 5 galllon bucket. You will catch a LOT of large pieces that would have clogged the tip. 2) Change all steel valves to brass valves. 3) Clean out the little "chips" of assembly metal carelessly left when the Chinese workers cut the pipe threads. I got about 10 metal chips out. 4)Most important is a small rubber gasket just behind the white porceline tip in the gun. Remove it and replace it with rubber washer, or an "O" ring, or just wallow it out on the inside to a larger inside diameter hole. This little bogus thing was trapping sand and clogging cause it squishes too tight and the inside hole gets too tiny.
I buy bulk "fine" sand from a quarry for 3 dollars a 100 pound bag, and after I screen it for stray large particles, it has worked perfect.
My HF pressure blaster has done everything from rusty wheels, to valve covers, exhaust manifolds, and fenders, etc FANTASTIC. But it needed the aforementioned re-working!
I first thought my problem was too much humidity, but I sandblasted on a horribly humid day and got very little clogs from the water.
I used 65-85lbs pressure from my 5hp 20 gallon compressor and everything worked super.
Professional sandblasters told me DO NOT attempt to blast your hood or any other relatively thin expanse of sheet metal that needs a super smooth paint job (they hate trunk decks too) until you are an Expert plus. Most rounded, real thick AD truck parts are OK; BUT experiment first on big thick stuff like wheels, or parts that wont show a "wave" that a poor sandblast job might put into really thin metal.
Good luck, hope this helps john 1952 COE 2 ton 1947 COE semi | | | | | Joined: Jul 2001 Posts: 15 Member | | Member Joined: Jul 2001 Posts: 15 | yes extremly helpful jhonny,thanks for the aditional help guys
| | | | | Joined: May 2001 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: May 2001 Posts: 71 | I have vowed never to shop at Harbor Freight again. Tried to order an oversized air cap and needle for their HVLP spray gun. Received a router depth gauge instead. To return it, you have to call them, they have to send you a return label, then you have to wait for the right item. Still haven't got it. Their cheap prices reflect their lousy customer service, I'm afraid. | | | | | Joined: Sep 2001 Posts: 30 Member | | Member Joined: Sep 2001 Posts: 30 | While im no expert i will add my 2 cents worth.I used a cheap siphion model and to some degree was able to controll the intensity by adjusting the air presure.Iused both silica sand and and a black comercial blast material.Ihad no problem with the silica sand clogging but the comercial stuff seemed to work a lot better.it had a more jaged edge and hurt more in the eyes than the sand l.o.l Wich brings me to my next point.How ever much you spend on the gun,dont scrimp on the safty gear.
1942 1/2ton 1951 1/2 ton 1960 biscayne sedan 1968 ihc scout 1972 #### 3/4 ton
| | | | | Joined: Jan 2001 Posts: 198 Member | | Member Joined: Jan 2001 Posts: 198 | I built my own blaster using a 100lb propane tank a few valves, and then bought the sandblast hose & nozzle from Princess auto supply for around $40 replacement tips come in sizes from 1/8 to 5/8 in and are about $6 each. Found it works great for heavy guage metal ,(frames wheels etc.) BUT it does use a lot of air (5/8 nozzle about 110 cfm) for blasting i'am using a diesel road construction compressor with 200cfm, some rental places rent them as a set and will delever.  | | |
