0 members (),
107
Mod | | | Forums66 Topics128,265 Posts1,058,365 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | Hi ....OK explain this one. I have been getting little burps out the tail pipe going down hill coasting.....some loud backfires. I figure the Rodchester B needed the little mixture screw turned out for a richer mixture.....no deal no matter how much it moved out same old story....BUT.....I decided to turn it in and now the burps have gone away. I was told that I needed more of a rich mixture instead I leaned it out and so far no burps or backfires.......WHY?
Steve Ex-Army...Honorable Discharge...go Army! | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Unburnt fuel in the exhaust system? and O2 getting into the exhaust system?
I had the problem when "backing off" on the accelerator (". . . burps out the tail pipe going down hill coasting.....some loud backfires . . ."). It was corrected after lowering the float level in the carburetor and changing the exhaust gasket.
I do not know which solved the problem.
