1 members (Hotrod Lincoln), 118 guests, and 3 robots.
Topics128,093
Posts1,056,474
Members48,444
#1035702 06/15/2014 1:03 PM
I found a set of horns on EBay - they said they are from a 50's school bus, who really knows, but I got 'em.
I put a 12V battery on them for a sec. One hummed and the other made no sound.
How can I determine if they are 6V or 12V? How do I go about testing these?
Dual horns
Bob
1954 Chevy 3100 5-Window
1954 5-Window COE aka "THE BEAST"
Bill Ritchie's Original Truck
Granddad's Hardware Store: Ritchie Hardware, Concord, N.C.
Bethesda, MD
Did you ground the horn for your test?
Bigtonka
Posted some info on restoring a different type of horn but some of the info might help
Originally Posted by Bigtonka
Kurt,
That faint sound you hear when you release the button is indication that the contact points inside the horn need to be cleaned and adjusted.
When you remove the round cap you'll see something that looks like this....
CLICK
Those two nuts adjust slightly up and down and adjust how the horn sounds. You want to adjust them very slowly, 1/16 of a turn makes a big difference. Up or down too much in either direction will result in no sound. There is an electrical contact point that who's gap is set by playing with these adjustments. There must be a slight gap when set right, but not touching.
I find in the two old horns I've rebuilt a light layer of rust built up on these points, and using emery paper I lightly cleaned it up.
Good luck,
Mark
I did ground them, but this helps. Nothing like just taking something apart to see how it works anyway.
Bob
Bethesda, MD
