1 members (78buckshot), 112 guests, and 1 robot.
Topics128,136
Posts1,056,425
Members48,441
how many cubic inches i will have on a 261 with a 848 head and a .060 overbore... i am getting a headache trying to figure it out..:)
if you cant run with the big dogs...then stay on the porch
http://s202.photobucket.com/user/rcplumley/library/
Around 270 ci is my recollection.
I think I calculated this 39 years ago when I rebuilt my 261 0.060 over-bored.
Here are bore and stroke measurements.
Here is a calculator.
I'll calculate it, if you don't, after the movie I am watching is over.
269 Cubic Inches
Thanks, Jerry, my worn out memory is sometimes right.
Is the factory calculated displacement just the cylinder bore x stroke height, or does it include the entire combustion chamber (including the head portion of the combustion chamber)?
Piston displacement is simply the air volume that moves through the engine when the crankshaft makes 2 turns. Compression ratio calculations involve figuring in combustion chamber volume, deck clearance, head gasket volume, etc. Then there's that nasty one, volumetric efficiency, where port shape and volume, valve lift and duration, and all those other variables have to be considered. Around 90% VE is a pretty good rule of thumb for a somewhat stock stovebolt engine.
Wallaceracing.com has a ton of calculators that are darn accurate for figuring out what ya got. Darn near matched my dyno sheet and head flow numbers.
The accepted rationale for swept volume (rather than total volume) is that at the end of the exhaust stroke the chamber is not completely purged of combustion byproducts.
Yes, that does give an interesting advantage to a low compression ratio engine with some method of purging the chamber - such as tuned exhaust and/or a supercharger.
true on supercharger,im thinkin more about properly placed turbo.far enough away from motor so air is as cool going into motor as it would have been stock but under presure.i seen article where guy put turbos above rear axle in car to produce these results
A "properly placed" turbocharger will be as close to the manifold as possible to make use of the thermal energy. That hot gas has a much higher volume that the cool gas would have back at the axle, thus spinning the turbo faster....not to mention line loss of all the redundant plumbing needed.
whiskey runner,
Have these posts helped, or do you now have a worse headache?
