1 members (baldeagle),
80
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 112 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 112 | I have 50 1 ton pickup im just getting finished.. I have ordered a new master cylinder twice and it comes back looking identical but has very larger brake line fittings that dont match the truck fittings.. Are the master cylinders different for 1/2, 3/4, and one ton pickups? The normal online vendors usually dont have 1 ton stuff.
The napa dealer used the old one to get numbers and order, and says its the correct one.. Anyone have the correct part number/vendor to get the correct one ordered..
Old Truck addict 1950 chevy 1 ton napco 1956 gmc 1 ton dually napco 1954 chevy 3/4 ton napco 1957 gmc civil defense napco panel
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy dirtball, my research indicates the 1949 - 52 3/4 and one ton master cylinders are the same p/n, Raybestos p/n MC9221 1 1/4" bore with 1/2" X 20 t.p.i. port (1/4' inverted flare female). RockAuto has a manufacturer closeout at the moment $37.04 in Canadian dollars, hope that helps. | | | | | Joined: Feb 2014 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2014 Posts: 46 | ive seen kits for manuel and power brakes from 47-54 for sale on e-bay i think.if not try google search, include 47-52 chev or gmc,master cylunder.the new ones have 2 pots instead of 1.that sort of thing has saved my buns before!!!!!!!!!!!!!!!! .one power unit even had bracket to mount up the wider power unit.good luck with your project and i hope this info helped | | |
