6 members (1955 1 Series, 50Chevy3100, RdsLessTaken, DadsFirstPickup, tclederman, 1 invisible), 172 guests, and 3 robots.
Topics128,107
Posts1,056,225
Members48,436
#1035159 06/12/2014 4:03 PM
Will 235/75/15 fit on original 15 by 41/2 inch rims?I heard that they would work on non steering tires.And i just want them on the back 1948 1/2 ton.In another post DEVE said Walmart installed his 235/75/15 DEVE did you have any problems?thanks
That is what I have on my 52 1/2 ton. With stock wheels. Front and back. No issues but it might matter on yours. Look to see if there is clearance at the tie rods and no rubbing at full stop.
Steve H
Gas Pumper
Gas Pumper
I didn't have any problems, but that doesn't mean it's safe or a good idea. We have engineers that figure out what the parameters should be and if its ill advised, since I have gotten older, I would probably listen to them. A blowout could cost you more than proper size tires.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
A 4 1/2" wheel is about 2" too narrow for that size tire. It will not provide very good sidewall support. While you may not notice it on the back, on the front that combination will cause road wander. There is also a possibility of the tire unseating itself from the bead if the pressure gets too low. A better choice would be at least a 6" wheel, 7" would be the best fit.
Bill Burmeister
I have 235/75/15 on the back of my truck. They are mounted on 10in wide wheels. I just went out and measured the tread width, 7.5ins on the ground. Probably a 8in wide wheel would be best, but the 10in are what I had, they look good and so far no problems.
I'm with Deve on this one. They will mount on the 4 1/2 inch rims, but you will just have to hope that they will "get you most of the way home" (as I always say).
Thanks for all the helpful information about about 235/75/15 tires.I will look for some wider rims be before i buy taller tires.thanks
Riding in the Passing Lane
A good rule of thum is the wheel width the same as the tread width.
1972 Chevy c10 Cheyenne Super
I just put 215/85r16,s on my 16 inch rims. See my post under general truck talk dated 5/3/2014. I had 2-5 inch rims 2-4.5 inch rims and a 4 inch rim. The tire fit fine on all of them.
1973 to 1987 chevy and gmc 4wd 6 lug rims will work fine, and are relatively ez to find. Those rims will measure 15x8. It has long been popular to put tire sizes up to 35x12.5 on those wheels.
