3 members (RoadsScholar, Gray_Ghost, Steelonsteel), 111 guests, and 2 robots.
Topics128,070
Posts1,055,892
Members48,428
#1034881 06/11/2014 2:19 AM
I am rebuilding a 62 235 engine out of a c10 to put in my 51 3100. I would like to use a 261 cam, specifically the Sealed Power cs-293 cam. It says it fits the 56-58 235 but does not list the 62. Is this just because it was not offered in the 235 in 62? Is there any reason this cam won't work. I would also use the vs424 valve springs. Can anyone tell me if sealed power offers the right lifter? I have not been able to find the part number.
I am also thinking of boring the block .040 over since the pistons are shot. Is there any benefit to milling the 848 head and if so how much?
Thanks for your help!
51cowboy #1034889 06/11/2014 3:00 AM
I believe the 261 cam will work in the 235 1962 block. Just make sure you match it up with new lifters. Mine is a 56 block and i am running a stock 261 cam in mine. I am not really sure what the difference is between the 56 and 62 except the elimination of the side front motor bosses and the external oil line vrs. Internal oil line in the newer block. You might want to call Patrick's Antique Cars and Trucks in Az or the cam manufacturer To double check.
The Classic Chevy Truck Handbook written by Jim Richardson. Has some good reading about to 235 motor Talks about mailing the head and decking the block. If you take too much off your will raise the c ompression to high And you won't be able to run pump gas.
Don't know anything about the springs you are putting in.
The bad part was I found this book after I rebuilt my motor. Its still good reading material now me.
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen
56 Chevy 3100
Tiny_Jaime #1034930 06/11/2014 12:31 PM
Thanks for the info. I am getting a copy of the book and will call Patrick's also.
51cowboy #1034948 06/11/2014 2:39 PM
I can't see any reason it shouldn't work. I know in '59 they changed the cam profile a bit and increased the compression ratio. The engine in 1958 was rated for 145hp/210 lb/ft, in 1959-'62 it was rated 135hp/215 lb/ft. A decrease in hp, but an increase in torque. Of course this was on car engines with a hydraulic cam.
51cowboy #1034951 06/11/2014 3:05 PM
Late 1954 through 1962 cams will all interchange.
My Blog
Pre '68 Dave #1035020 06/11/2014 11:10 PM
Thanks everyone! This is what I was hoping to hear.
