4 members (dogdaddy, Ponchogl, 2-Ton, 1 invisible), 72 guests, and 2 robots.
Topics128,037
Posts1,055,463
Members48,422
#1034919 06/11/2014 5:32 AM
A couple months ago I bought a 1950 1/2 ton. When I bought it I asked the guy if it had any 12v conversion and he said that it had a 12v starter. I assumed that it was converted. After I got it home it has issues starting, if it doesnt start right off then the battery drains. But with a jump it runs like a champ. After looking I noticed that it had a 6v battery. Looking further it actually has 2 batteries, they put in an additional battery tray in behind the original one. It has a 12v battery with a solenoid that connects the 2 batteries together. There is also a starter button in addition to the starter pedal. Is this common? Can I just convert it to 12v easily? How do I know what has been converted to 12v already?
It is not common.
Does it have 6v or 12v bulbs (head lamps are the easiest to check on this).
If it is 6v (with a 12v power "enhancement" to a 6v starter), you can get a good 6v battery (like an Optima), get proper 6v battery cables (0 or 00 gauge), and clean all cable/ground connections, and get it to reliably start as a 6v system.
If there is a metal ID plate on the body of the starter, what color is the plate (6v is black and 12v is red)?
I have seen a setup like that before, a work around for starting old snow plow trucks.
The whole truck should be stock 6V and the second battery is connected when you push the extra starter button. Like attaching a jumper battery but you don't have to connect the cables.
The problem is that you have to connect a charger to the second battery once and a while because it isn't charged by the truck.
The starting procedure is: key on, stomp starter and then push the button while the starter is down for the boost.
A real asset in the middle of a blizzard.
It appears to have 6v lights and a 6v starter, it also has a very large battery cables.
It sounds like it is a backup battery like was mentioned. Do I just hookup the backup 12v battery to a charger?
yes, but check the water first. There is a good chance it hasn't been checked or charged for a while.
If you're lucky it will hold a charge, but there is a chance it will be dead from neglect.
The truck should start normally on it's original system. Find out why the 6V is running down.
