1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2001 Posts: 194 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 194 | What do I use to seal the seam between the top of the cab and the back of the cab on an AD? You know, the seam at the belt line.
I also need to know how to apply it. The factory assembly book says to apply a 1/16" bead under pressure to this seam.
Any help on what to use and how to apply it would be greatly appreciated.
Thanks, Arlyn :confused: | | | | | Joined: May 2001 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: May 2001 Posts: 71 | Do you have an Eastwood catalog? I used #31024Z. The beige stuff. It worked great and is sandable and paintable. Website is eastwoodcompany.com | | |
