5 members (Steelonsteel, Tyler Watts, RaNfLaS, rfs56trk, DadsFirstPickup), 101 guests, and 2 robots.
Topics128,048
Posts1,055,663
#1034538 06/09/2014 7:16 PM
As you can see in the attached pic the upper shift lever(arm) popped off its shaft during a shift sequence. It's a press fit. Any suggestions for repairing this after the box is removed?
http://pic100.picturetrail.com/VOL1061/3611363/24441783/409601966.jpg
Drew
don't think I'd trust anything other than some spot welding, but make sure you get it back in exactly the right orientation
I would look for another box. Unless you get it in the exact correct spot, you will have a nightmare trying to get it to shift.
Thanks for the advice.
Drew
Riding in the Passing Lane
What year is that?
1972 Chevy c10 Cheyenne Super
When you take it apart, see if you can see if there are any broken weld marks to show you how it goes back together and either TIG weld it or have someone do it for you. Looks like it is somewhere around a 52, judging from the adjuster nuts on the control arm rods.
I looked at a box I have on the bench, that arm is swedged onto the brass or bronze bushing that carries the shaft thru the case, doubt it will be evident how to position it - you might be able guess close with fingers crossed by comparing to a good one with things in neutral - here's pics of boxes I have
It's a 1950 version. Red58, that's what I was thinking. I have the trans in neutral and was thinking I may be able mark the lever and case since both arms should be parallel in neutral.
I had this box apart to clean it some time ago, and all the innards were fine. Hoping to still find it that way.
Drew
