0 members (), 166 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
#1034298 06/08/2014 4:43 PM
I just received my gauge resurface kit and discovered that it has 90 mph sticker for the speedometer, but my 50 chev has 80 mph speedo what gives?
How much will it screw up my actual speed shown when driving if I use it?
1950 Chevrolet model 1434 5-Window Canadian manufactured 1-Ton with Dump Bed / Hoist
You will never stop learning new things, no matter how old you are.
The kit you have is for '52-'53. You have two options; (1) get the proper '47.5-'51 kit, or (2) run a taller tire to match your vehicle speed to the new 90 MPH speedometer sticker. Option 1 is correct for your year. Option 2 is more expensive but would lower your engine RPM a bit due to the use of taller tires.
Those stickers are cheap, order the correct ones. You will eventually find someone who will buy the 90 mph ones.
Another reason to order the correct one, the high beam indicator for your truck is on the bottom and the 90 mph is on the top. You need part #24-010 ($12.95) at Classic Parts.
RdsLessTaken/Don
My time Machine:
http://s1291.photobucket.com/user/RdLessTaken/media/IMG_85261_zps90bf2b98.jpg.html
