6 members (Hotrod Lincoln, GMCJammer51, jmoore, Forty9, 2 invisible), 117 guests, and 1 robot.
Topics128,196
Posts1,057,385
Members48,469
Hey all,
Trying to clean up my cluttered shop yesterday, and came across this part. It was attached to the speedometer port on a civilian 4 speed non-synchronized transmission attached to a Frankenstein 235 engine. What year or model the part was from is anyone's guess as the engine/trans it came from had components with casting dates ranging from 1937-1959. It think it has something to do with a two speed rear. Anyway, I would like to know what it is and what it does. If you can answer my questions, and you need one, it is yours for the cost of transportation.
[img]http://www.surfacezero.com/g503/data/3764/IMG_56401.JPG[/img]
[img]http://www.surfacezero.com/g503/data/3764/IMG_56381.JPG[/img]
[img]http://www.surfacezero.com/g503/data/3764/IMG_56391.JPG[/img]
Paul
Lots more pictures
speedometer adapter for 2 speed rear I believe, should have a vacuum or electrical connection to change ratio when the rear is shifted - I've always seen them on the back of the speedo
Paul,
Red IDed it.
My 54/55 GMC 2-ton COE has that type of adapter for the speedometer and two-speed rear-end. I think that Jim Carter sells a 9-foot-long cable with the wider end-cap needed for that switch (I hope it works).
I do not know how the 2-speed selector-switch attaches to the speedometer adapter but I will be dealing with it this summer as I put the painted COE sheet-metal back on top of the engine. Spanky will be my savior.
I agree it's a 2-speed speedometer adaptor. I'm not familiar with the older mechanical 2-speed linkage, could the dash mounted lever have been connected to the adaptor somehow?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
"Identify this part, and if you need one...you can have it!"
Paul,
If Red does not want it, I'll take good care of it (and pay for shipping).
I don't want it Tim, I've had 2 from TF big trucks I couldn't give away, finally went with a load of scrap ohwell
I think all of them had either vacuum or electrical switches that were connected to the shift mechanism [vacuum or electric] so when the rear gear was changed, the speedo "automatically" followed
I
I Offline
Is the speedo adapter vacuum operated? If so, I'll take it if nobody else wants it smile Oops, I see tclederman beat me to the punch, LOL......Well, if tc changes his mind I'll take it smile
H Online: Content
There's supposed to be a small vacuum diaphragm or a cable from the shift selector to switch positions as the Hi/Lo selector is moved, IMHO.
Tim,
PM me your address.
Paul
Lots more pictures
That is the speedometer gear change for a 1946 or earlier Timkin 2 speed rear end. It is MECHANICALY shifted, operating off of the rod that runs from the transmission mounted shift lever all the way back to the actuator cable that moves the shift lever on the rear end itself. NO vacuum or electricity involved.
If you've got another, I could use a spare for mine!
1945 1.5-Ton Chevy Big Bolt
Maynard
More pix of the old truck
Sorry Chuck, Tim's got dibs on this one.
Lots more pictures
Drydock, check your messages
Lots more pictures
