0 members (),
140
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 293 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 293 | I just received my gauge resurface kit and discovered that it has 90 mph sticker for the speedometer, but my 50 chev has 80 mph speedo what gives? How much will it screw up my actual speed shown when driving if I use it? | | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | The kit you have is for '52-'53. You have two options; (1) get the proper '47.5-'51 kit, or (2) run a taller tire to match your vehicle speed to the new 90 MPH speedometer sticker. Option 1 is correct for your year. Option 2 is more expensive but would lower your engine RPM a bit due to the use of taller tires. | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | Those stickers are cheap, order the correct ones. You will eventually find someone who will buy the 90 mph ones.
