4 members (Oswald, treegrower, Nick in Manitou, 1 invisible), 40 guests, and 3 robots.
Topics128,076
Posts1,055,920
Members48,429
#1034156 06/07/2014 10:11 PM
Recently put in a radio into my 46 Chevy 1/2 T and used the placement from pictures of one installed by Tim Sheridan-46ChevyTruck.com , however I didn't see any photos of how the speaker was mounted and where it was mounted... Can anyone help?
Thanks, Ryan
1946 Chevy 1/2 Ton
More pix on Photobucket
1946 Chevy 2 Ton
"if it ain't rattlin' it aint broken"
The speaker should be mounted inside the radio enclosure to the bottom cover.
Ryan,
If you are using the correct radio for 1946, the speaker is self-contained and faces downward when the radio is installed.
Look at the photos following:
1946 Radio
Harold
Harold
I have the same model of radio, but mine came with the speaker mounted on top of the radio in its own bracket. I had to remove it from this position as the speaker would hit the headlights switch, I'll try tomorrow to see if it will fit in the cover or not...
Also, didn't have any of the brackets to mount it. So, I made custom brackets for the front which work fine, But I have no clue as to what to hook the back bolt that comes out the back of the radio to. I was going to hook it to the fire wall, but didnt think that was the most convenient to hook to. Any ideas on this?
Thanks again Ryan
1946 Chevy 1/2 Ton
1946 Chevy 2 Ton
Ryan,
Look at my photos & you will find a drawing of the bracket you need with dimensions. Very easy to make.
Harold
Harold
Thanks, The speaker does fit in the cover and that solves that problem. I am currently making the bracket for the back of the radio, however I am still confused as to what I am supposed to attach it to. ~Ryan
1946 Chevy 1/2 Ton
1946 Chevy 2 Ton
It's almost like it needs a 'sky hook' (sorry old Navy term for a mystery place to attach things). Really there is an odd length of angle iron of sorts that runs across and above the radio to mount it to. I'll try and find some pics of how I did mine. I may have to just email these pics as I'm just starting a new photo hosting site, not going well.
Jim
1946 1/2-Ton Chevy
Ryan,
Install the radio below the dash to the left of the steering wheel with an L-shaped bracket on each side of the radio up front and a slightly bent bracket from the stud on back of the radio to the end of the wishbone (radiator support)rod that extends thru the firewall.
Truck Radio Chevrolet Model 986146 RADIO
Harold
Harold
Oh, Alright. Thanks, I was going to attach it to one of the bolts for the horn on the fire wall. But, attaching it to the radiator/hood support seems to make more sense to me. Thanks, Ryan
1946 Chevy 1/2 Ton
1946 Chevy 2 Ton
Moderated by  truckernix
