| | | Forums66 Topics128,175 Posts1,057,053 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | After reading another post by Denny G about quality control on intakes and exhaust manifolds I have a question about my manifold. I bought it from Patrick's over a year ago and I have not called them I just thought I would throw it out here. I just noticed a few weeks ago actually, on my Fenton intake that if it sets on my table with the heat plate side setting on the table that the one end port touches the table, the middle port is a little higher of the table, and the other end port I can put my finger between the table and the bottom of the port. I did not take measurements. My intake actually has fall towards the front of the engine when installed. It seems to mate up fine and set flush. I had to make some mounting brackets on both ends of the intake in order to install the Fenton Intake and Exhaust manifolds. I saw some other pictures on the www of other 235's and Fenton's and I see them with a similar fall to the front of the engine also. I did not catch mine until I had it powder coated. Is this normal? If not does it hurt anything? any ideas thoughts or comments. towards front Middle toward back without carbs and after powder coat with carbs before powder coating
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | maybe made so it sits level when mounted to the engine. The engines usually sit with a rear down tilt.
John | | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | I am hoping it is that simple. I was just wanting to make sure that I didn't have that one weird intake however if that's the way it's supposed to be I am really good with that.
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | It is usual for the engine to slant and the carb base to be level. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Fenton is the only maker of the after market intakes for Chevrolet 216-235-261 that purposely made their intakes to be level when used on a 216-235-261 Chevrolet when the engine is in it's stock mounted position. All others DO NOT set level to the ground, but level to the engine. Why? I don't know.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | Great Explanation. I guess I can stop worrying about it now. I talk to another guy at work And he said it would make sense for it to be ground level than engine level Because of the carburetors and the floats. Now it make sense to me why they would do something like that.
