2 members (MickeyP, Charles in CA), 38 guests, and 9 robots.
Topics128,012
Posts1,055,311
Members48,419
#1034178 06/08/2014 12:02 AM
I am now in the process of reworking my doors and windows on the 59. I have all new stuff to redo the vent seals. My question is the big rubber seal around the vent glued, riveted or how does it come out?
I have drilled out the rivets and have the frame out, but cannot see what holds the seal in.. My manual does not show this in detail. Thanks. Tech Tips shows an older model.
57 GMC LCF 370
55 John Deere 40-W
59 John Deere 430-W
2000 GMC 4x4
56 John Deere 420-W
Pix on Photobucket
Old GMC Gold #1034181 06/08/2014 12:10 AM
I am doing the same and found a very useful thread with lots of links that might also apply to a 59. There is a lot of info in this thread thanks to other Bolters
Window felt thread
Bob
1954 Chevy 3100 5-Window
1954 5-Window COE aka "THE BEAST"
Bill Ritchie's Original Truck
Granddad's Hardware Store: Ritchie Hardware, Concord, N.C.
Bethesda, MD
Old GMC Gold #1034199 06/08/2014 12:59 AM
the shaped one around the front of the frame is cupped on the edges to 'grip' the frame, the straight division post rubber is riveted, and there's also separate rivets that hold the felt channel side on the post - there's a few pics starting here that might help - note there's also rivets that hold the frame to the post, might need to drill those out as well, I fergit grin
Sir Searchalot
Sir Searchalot
As Bill says, the three sided rubber snaps into place. You have to work it in with different non cutting "tools" until you hear it pop. The forth side is riveted and I believe I bonded the division bar felt into place with 3M super weatherstrip adhesive. For the run channel there is a keeper down inside for the bottom and the rest I use tiny screws at/near corners and 3M and clamps. The run is the hardest part for me. Getting the vent glass back into the frame is hard also. Cut that run after the vent is all in place and cut it long because no matter how you measure it , it will sink in deeper and be too short where it meets division bar. You may not want to bond the run at all, some folks do not, I do. Have fun with those anti rattle wiskers, the nubs don't match the holes and you can't push in, no access. I shaved some of the nubs with a die grinder a tiny bit. What a hassle.
Old GMC Gold #1034250 06/08/2014 12:37 PM
Thanks Guys!
57 GMC LCF 370
55 John Deere 40-W
59 John Deere 430-W
2000 GMC 4x4
56 John Deere 420-W
Pix on Photobucket
Thanks Bartamos and Bill. Bill I am glad you posted the pictures, they cleared up another problem I thought I had.
The little stud that the vent window handle goes on.....I thought mine was broken/rusted and a part of it was missing. But I see that it is only half round where the roll pin goes.
Mine was missing the lever, so I did not know this.
57 GMC LCF 370
55 John Deere 40-W
59 John Deere 430-W
2000 GMC 4x4
56 John Deere 420-W
Pix on Photobucket
Moderated by  ndkid275, Phak1
