1 members (Gray_Ghost),
77
Mod | | | Forums66 Topics128,128 Posts1,056,358 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | What is the Front and Rear WMS-WMS of a 52 1/2T? Need to know exact please. I don't always trust the internet bloggers or Wiki. Need to know from Stovebolters. Thank you.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | WMS = Wheel Mount Surface Someone will have to measure it for you, if you do not have an A-D 3100 to measure. The following measures might be what you are looking for? Here are measurements of center-to-center of wheel-to-wheel (center of tread tire-to-tire) front = 56.75" rear = 61" ( also shown here) Note: front measurements are slightly different in 1949 (huck brake spindles?) and in 1954/55 | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Thanks TC. Now if I knew the +/- offset of the stock wheel
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Here are offsets for 1952 truck wheels. Is that what you need? | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | If I add or subtract 2X the offset to the center of tire dimension, I get the WMS. If I knew what 9-16 is. Assuming it is 9/16 and it is positive: 56.75 + 1.125= 57.875 WMS. Someone may chime in with an actual measurement. thanks again
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Then I think I have my answer. waiting for actual measurement. Will be interesting to see if it checks out someday when you take your 5 window wheels off. or did you say 54 is different.
