4 members (baldeagle, Jon G, Oswald, 1 invisible),
57
Mod | | | Forums66 Topics128,015 Posts1,055,334 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | do you know the dimensions of the canister? measurements of the old filter? diameter, height. | | | | | Joined: Aug 2013 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 255 | No, was hoping to get a new one ordered before I pulled the old one out for an oil change. Didn't measure the canister but will tonight. Might just pull it anyways. Need to clean the engine up also. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | here are two ...pic... the wix is 4 inch diameter the fram is 4 1/2 diameter I believe they are both 4 3/4 tall don't know if that close to what you have | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | The key is the center post gasket. The height/width is really not an issue as long as the return hole in the standpipe is covered... and you can adjust the height of the filter with washers. My trucks us a variant of the S-2 but called the 'Military Senior filter' (my jeep uses the Military Junior filter). NAPA Gold 1503 or WIX 51503 http://www.fleetfilter.com/mm5/merc...mp;Product_Code=51503&Category_Code=Going price is about $8-$9 There used to be a place in NC that would ship any case you ordered for $0.99. Lost the link t hough | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Width is an issue if the filter is a larger diameter than the canister.
| | | | | Joined: Aug 2013 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 255 | Thanks for all the replies. O'reilly's ordered all that they had listed for that year GMC, so I've got a couple choices when I pull it next week. Hopefully one will fit. Guess I'll have to wait on the gasket for the canister till I've got it pulled. Jim | | | | | Joined: Dec 2008 Posts: 898 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 898 | I have a Wix 51100, it's 4.75 tall and just a shade over 4" in diameter.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | There used to be a place in NC that would ship any case you ordered for $0.99. Lost the link t hough That would be a good deal | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | I have a Wix 51100, it's 4.75 tall and just a shade over 4" in diameter. Thats the same filter I use in my 42 Ford. But the 270 should have a MUCH larger can. LOOK AT THE SIZE OF THE OIL FILTER! You'd have to stack 2 of the 51100's to fill it up... that's if you have anything close to a proper oil filter. Also, the 51503 is 4.093 in diameter.
| | | | | Joined: Aug 2013 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 255 | The 51503 fits, it had a Hastings LF 106 in it. Thanks for all the replies. Jim. | | |
