0 members (),
149
Mod | | | Forums66 Topics128,113 Posts1,056,619 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2002 Posts: 43 Junior Member | | Junior Member Joined: Oct 2002 Posts: 43 | I noticed on my wood floor boards there are no short braces between the wheel wells. BUT there are bolts that go through the top hold down strips but just bolt up beneath the wood underneath. :confused: Is the correct? Would it be wise to make 2 short metal braces like the long one that doesn't bolt to the frame anywhere just the wood. Make two like that to put inbetween the wheel wells? for extra strength and keep the boards from dipping down in the middle if there is weight on them? Or would it not help it from doing that at all? Thanks for your comments.  | | | | | Joined: Apr 2002 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 146 | The bolts that are hanging out in space. They just get a large flat washer on the back. You could make a bracket, but it might hold the wood too tight. You could end up with split boards.
if it dosen't need fixed, break it
