| | | Forums66 Topics128,269 Posts1,058,399 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 51 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 51 | 1950 one ton panel, the rear doors have two brackets on the top that can hold the doors open, there is a rubber bumper on them. Does anyone know what these hinges are called and where can I get the bumpers for them
1950 one ton panel, 1959 half ton apache
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | they're called check arms because they prevent the doors from opening too far, and I don't think the bumpers are reproduced for any series, you'd have make some yourself out of a block of rubber if you have a decent piece to duplicate, not a complicated shape
Bill | | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | I made one out of rubber, it has served me well, just have to do the other side yet. | | | | | Joined: Jan 2011 Posts: 51 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 51 | Ok that helps thanks a lot ,
