8 members (TexasA&M48Truck, Peggy M, 1955 1 Series, CuzzFuzz, greenie-reddy, Forty9, Hotrod Lincoln, thekid1950),
50
Mod | | | Forums66 Topics128,012 Posts1,055,320 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 60 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 60 | So after getting this running decided to see if I could make it stop master cylinder was bone dry filled it and pumped up pedal then worked on bleeding and refilled. Now here's the problem the dang things don't release if ya walk away and let it sit awhile pressure bleeds off and they are free I'm kinda stumped! 58 Viking 60 by the way | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | most likely cause would be bad rubber hoses, they can deteriorate inside and rubber plugs it enough to prevent or slow pressure release, best to replace them
Bill | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy coal, It could be that the compensating port in the master cylinder is plugged with something, or the master cylinder is not returning to its full at rest position. When you have the cap off of the master cylinder you should be able to see two ports a larger port to the rear and a much smaller port forward of that, that one is the compensating port, check that port with a bit of fishing line to make sure it is open, hope that helps. | | | | | Joined: Apr 2009 Posts: 60 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 60 | Thanks for the input got bigger fish to fry with the clutch problem now | | |
