0 members (),
136
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 34 New Guy | | New Guy Joined: May 2012 Posts: 34 | hi, i am thinking of renewing my hood emblem on my 1950 3100, i am not sure to go the chrome or stainless route. most of the replacement chrome i have renewed has started to rust slightly and it has only been on the truck for a year or so. has anyone matched the stainless against the chrome? i am edging towards the stainless but am open to any suggestions. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | If you live in an area of high humidity, which it appears you do, and you don't want to be waxing often the SS would be the logical route, if you have a choice. The problem is, you don't always have a choice and the SS will not be as brilliant as the chrome but is low maintenance. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | As you're finding out the repro chrome items are less than satisfactory,my own rear tail-lights and brackets have rusted badly in a short time too.
Our councils love of road salt in the UK doesn't help either,even if you don't use your truck in colder weather i'm pretty sure there must be residual salts etc on the roadsides even after a while.
My stainless (original) hood emblem is on the other hand perfect.(At least as perfect as its 64 years will allow!)
So from that I would deduct,stainless is the way to go IMO.
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: May 2012 Posts: 34 New Guy | | New Guy Joined: May 2012 Posts: 34 | thanks for the replies, i think i might go for the stainless. my original is not too bad but it has a small split which would cause an injury if you rubbed your hand across it and the painted parts have been replaced with unsightly stickers at some point which are all peeling. i might try and fix the split and paint the blue and red before i make a decision but i think i would probably get a new stainless one that has been manufactured in the USA. | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | I purchased a new repop chrome hood emblem only to be disappointed in the fit to the hood. The curve of the emblem is not the same as the hood. It sits proud of the hood at least 1/8" at both ends. Maybe the stainless will fit better. If you go stainless, please report back on fit. Hood emblem | | | | | Joined: Feb 2000 Posts: 5,198 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,198 | If it does set funny, you can bend the stainless to fit where the chrome will crack. Color will be different, even polished out you can tell if you have them side by side. I would go stainless because it can be polished over the years and still look good.
Joe | | | | | Joined: May 2012 Posts: 34 New Guy | | New Guy Joined: May 2012 Posts: 34 | stainless it is then. when it turnes up from the USA i will report back davidf and let you know how good the fit is.
cheers all. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | stainless it is then. when it turnes up from the USA i will report back davidf and let you know how good the fit is. cheers all. Don't forget to order the mounting gasket. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | There was no mounting gasket originally John, that is a vendors invention. Denny Graham Sandwich, IL
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Anyone can have the mounting gasket I purchased. Currently it sits in the never to be used parts bin. The gasket is way too large and even if you trim it to a proper size will look silly sandwiched between the emblem and hood. Also, I would think it to be a debris and ultimate moisture trap. No thanks. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Denny is, of course, correct (no "gasket" was used by GM); and, I reached David's conclusion for not using that emblem mount "gasket" (protector) with a 54/55 Chevrolet truck hood front emblem. However, I can understand someone else choosing/wanting to use one to protect the paint. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Cheap chrome jobs(off shore) that rust right away are not 'triple plated', Cu first, then polished after all blemishes are removed, then Ni, then Chrome. Ever seen a Model A Ford hood, they were only finished with Ni.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | You mean a model A radiator Ed? Yep, no chrome plating over the nickel, gotta keep the polishing rag going to keep them shining. dg
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | There was no mounting gasket originally John, that is a vendors invention. Denny Graham Sandwich, IL I stand corrected Denny,never having seen a totally original truck I just assumed mine had turned to Bakelite and fell apart long before I ever set eyes on my truck.  To be honest I don't have one either.....
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I think the hood emblem is like the rear fenders. A lot of people gasket the rear fenders also but they never did have anti-squeak in them either, cept for the burbs. The trucks only had a thin coat of primer under a relatively thin coat of paint so assembling them paint on paint wasn't really a problem.
Today when we attempt to 'restore' them to their original look, we WAY over do it with multiple layers of primer, sealers, fillers and heavy coats of paint. And in many cases several heavy coats of clear so we can color sand this thick soft layer of finish to give it that glass smooth look. I've heard guys boasting that they had applied a dozen or more coats of buildup to get that show quality finish. So of course paint on paint or metal on paint is going to chip the soft paint layers. Nothing stands out more than a Stovebolt all decked out in a nice mariner blue dress with white primer showing thru her chipped paint. DG
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Denny, as usual you most likely have it exactly right. However, I am in the camp of using "welting" between fender and other sheet metal for two reasons: Protect the paint and fill the "gaposis" caused by poor factory flanges and perfectly flat box side sheet metal. Besides, most people don't know the welting doesn't belong on the truck. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I think the hood emblem is like the rear fenders. A lot of people gasket the rear fenders also but they never did have anti-squeak in them either, cept for the burbs. The trucks only had a thin coat of primer under a relatively thin coat of paint so assembling them paint on paint wasn't really a problem. I was under the impression the truck beds were painted with the rear fenders on? ...in this pic... You can see original red paint runs on the bed sides. My truck was originally red. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | And you are correct from what I've seen Gus. I do believe the beds were assembled with the fenders and the whole thing shot. I've also got similar pictures of my '50 somewhere on a dead computer hard drive, that looks just like that. You can see the break where the original paint and black e-coat meet with the fender off.
They used fender welting as anti-squeak in the front fender because with every thing hung off the back of the clip it would move around some, where there would be very little if any movement of the rear fenders.
DG
| | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | My 54 appears to have been painted without fenders from factory. MT posted pictures of 54 bedsides that appeared the same. Paint between fenders and bedsides extending under the rear fenders...Maybe a change in the process over the years? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Quite possible Greg, as we've observed over the years there were many variations in the assembly lines from one year to the next and the different locations had their lines laid out differently and I'm sure management had different ideas for the production flow at there location and even the line supervisors right down to the guy that actually pulled the trigger would have had their own best way of getting the job done. So it would probably be more accurate to say, trucks coming out of some locations had the bed & fenders bolted together before they got to the paint line. But getting back to the subject, the hood emblems were never, at any of the plants, applied with a gasket behind them. Denny G
| | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | So weighing the evidence, I asked what the reason for a change in the process might have been. The answer may have been as simple as the angle of the top of the bedsides...Maybe it was too hard to paint under the flat bed rails with the fenders on. | | |
