2 members (jmoore, Rusty Heaps),
91
Mod | | | Forums66 Topics128,264 Posts1,058,350 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 51 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 51 | I have a 1950 1 ton panel and am wondering what type of radio antenna came with them. My truck has a hole on the side of cowl passenger side
1950 one ton panel, 1959 half ton apache
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Here are instructions. I think someone posted a drilling template (one comes with the reproduction antenna sold by most parts vendors). The side cowl antenna was used on pre 1947 Advance-Design trucks, I think. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Mar 2002 Posts: 9,116 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,116 | So if you look at the template, you will see the diameter of the hole. If you print it out, make sure that the hole on the template is the correct size on the paper. Also,the antenna goes on the driver's side. | | | | | Joined: Jan 2011 Posts: 51 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 51 | Thanks, my panel came from a Texas oil rig service company, so they must have had a two way radio antenna on the right side which would explain the hole on the right
