| | | Forums66 Topics128,152 Posts1,057,011 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | My return springs on the inside door handles seem pretty limp. Would that be why my door doesnt always close? Also, do you have to replace just the spring or the whole door relay linkage? Thanks - Scott
55 1st Chev.
| | | | | Joined: Jan 2000 Posts: 20 Junior Member | | Junior Member Joined: Jan 2000 Posts: 20 | Scdascda, I was having the same problem. If you can find an unbroken spring, the assembly can be taken apart and the spring replaced. A weak or broken spring will allow the door handle to stay in the back position and the door will not latch unless you manually push the handle forward before closing the door.
I found a couple complete relays with good springs for a dollar apiece at Carlisle Saturday. It was easier to put in the assembly than take it apart for the spring. Pete
Doug Peterson 53 Chevy Pickup | | | | | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | Thanks Pete, that is just what I needed to know!
- Scott
55 1st Chev.
