4 members (fonz8261, Otto Skorzeny, King Kielbasa, 1 invisible), 90 guests, and 4 robots.
Topics128,077
Posts1,056,015
Members48,433
#1032924 06/02/2014 5:34 PM
I have a 1962 C20 that originally had a 235 in it but now has a 305 V8. I think the front end sits down to low for me. I have found stuff on the net about loading the front by adjusting the torsion bars but none are very clear. Do you turn the but in to raise the front or out?
Yes, tighten the bolt to raise it, loosen it to lower. You'll want to get it re-aligned after the adjustment, as the ride height change will alter the camber and toe settings.
It does strike me as being odd that the truck would sit lower with a 305 in place of the 235, the 305 is a lighter engine by about 40 pounds. If anything, it should sit up higher. There's a possibility that your torsion barn might be a little weak. I don't know of any replacements being produced for them at this time, or if bars from a later truck ('88-curent) 3/4 ton will work.
Bill Burmeister
Thanks, they may have been adjusted down before the engine swap I just can't remember.
