Good to see you posting again Jerry, hope all is well with you and the Gold Wing.
I did notice a drainback hole in the bottom of the rear main cap and it wasn't clogged. There was a slight wearing away of the top babbitt coating at one small corner of the rear main but otherwise the rest of the bearing looked good. The crank also looked good with no discernable ridges or scratches.
If the engine makes it to the winter I'll be hitting a crossroads of sorts, rebuild it or go for some more performance...
I'm just enjoying the cruising too much now to take it down
You still wanna get rid of one of your late model 235's?
Jim, that does make alot of sense and could be the reason.
