1 members (Bill Hanlon), 48 guests, and 5 robots.
Topics128,012
Posts1,055,318
Members48,419
#1032733 06/01/2014 8:21 PM
I need info on glue for 2 locations:
The roof in my cab is painted. First I glued the repo plastic headliner in with 3M spray adhesive. First time out in the sun it came loose.
Second time I went to the hardware and got Dap contact glue. Next time out in the sun it came loose.
Anyone have name and part number for something that will hold?
Also what part number for contact glue for door weather stripping?
Thanks for any help.
57 GMC LCF 370
55 John Deere 40-W
59 John Deere 430-W
2000 GMC 4x4
56 John Deere 420-W
Pix on Photobucket
Old GMC Gold #1032740 06/01/2014 8:52 PM
are you using the contact cement properly? spread on both surfaces, not too thin, let it get tacky before mating,, apply pressure everywhere with a roller - and you might need to use a cleaner on the paint, especially the 2nd/3rd time .... I've not had 3M spray fail on my headliner or anything else .... and 3M weatherstrip adhesive does the door seals well, it's really a contact cement too
Old GMC Gold #1032916 06/02/2014 5:05 PM
Thanks Bill. Yes I did the contact glue like you said. One thing may be a problem, the headliner came from Car&Truck shop and it is sort of corrugated in small squares.
57 GMC LCF 370
55 John Deere 40-W
59 John Deere 430-W
2000 GMC 4x4
56 John Deere 420-W
Pix on Photobucket
Old GMC Gold #1033073 06/03/2014 4:09 AM
Which 3M did you use? I'm partial to Super 77, I used it to install not only the headliner, but also the insulation in the cab. Still holding solid, even after 12 years.
Bill Burmeister
Old GMC Gold #1033118 06/03/2014 1:04 PM
I've had the 77 fail on light weight fabric headliner when it
got hot in the summer time.
Since then tried this, you make up your own mind:
DG
Denny G
Sandwich, IL
Old GMC Gold #1033203 06/03/2014 8:41 PM
My shop is 15 miles out of town, but I think I used the 77.
Denny, yes it is the sun that has caused mine to fail, both times. I will try the Hi-Strength 90 next. Does it seem to be working for you? I have become an expert at installing and removing that pesky rubber seal.
57 GMC LCF 370
55 John Deere 40-W
59 John Deere 430-W
2000 GMC 4x4
56 John Deere 420-W
Pix on Photobucket
Old GMC Gold #1033331 06/04/2014 12:53 PM
All you can do is give it a try. Just make sure you clean 'both'
surfaces good and are not trying to go over the adhesive that
was previously used.
DG
Denny G
Sandwich, IL
Old GMC Gold #1034153 06/07/2014 9:49 PM
Bill or anyone. Would you happen to know the part number for the 3-M weatherstrip adhesive for the door seals?
(the one that is a contact type)
57 GMC LCF 370
55 John Deere 40-W
59 John Deere 430-W
2000 GMC 4x4
56 John Deere 420-W
Pix on Photobucket
Old GMC Gold #1034160 06/07/2014 10:30 PM
Old GMC Gold #1034172 06/07/2014 11:45 PM
Thanks Tim. Lots of choices. I was trying to find the one the guy uses on the you tube video showing how to install door weatherstripping. It is in a red tube, black adhesive, and he says it is a contact also, but he does not tell the part number.
57 GMC LCF 370
55 John Deere 40-W
59 John Deere 430-W
2000 GMC 4x4
56 John Deere 420-W
Pix on Photobucket
Old GMC Gold #1034208 06/08/2014 1:45 AM
Most likely any auto parts store will sell it.
For example:
http://www.autozone.com/autozone/ac...-adhesive/_/N-255s?itemIdentifier=934735
Old GMC Gold #1034249 06/08/2014 12:34 PM
Thanks a bunch!
57 GMC LCF 370
55 John Deere 40-W
59 John Deere 430-W
2000 GMC 4x4
56 John Deere 420-W
Pix on Photobucket
Old GMC Gold #1048580 08/11/2014 4:08 PM
The stuff in the aerosol cans will let loose eventually. You need to use the stuff upholstery shops use. It won't let go in the heat.
